Made it into the 10s
    Yes Joel its the block you sold me..Scat forged 383,Dart LE2 heads,58mm tb,edelbrock ported intake,42lb injectors,Ridings converter,Performabuilt Level 2 4l60e,stock 10 bolt 3.73s,Qa1 front and rear shocks,120 shot....Best motor pass was 11.52....Tuned by DR.Phil
      Whats the compression on the engine?
      Originally posted by Yoshi94
          Awesome! I'm glad to hear that. Hope I can see this build in person this season!
            I really need to get a 12 bolt,before I break a new 10 bolt..lol........Also need to figure out why I cant hold the car at the line,it just pushes through the beems.I can only launch at 1500rpms..
              Whats your stall?
              Leaving on the footbrake correct?
                All Ridings converters are like that. Mine is so tight down low I can't footbrake it past 1700 without it pushing through the brakes. Still flashes to 4000 and goes 1.6x with 320hp tho so I don't complain
                  I had him "loosen"it up in Feburary this yr before I installed the motor and trans..It was much worse last yr..Its a 3500-3800 stall.everything works great together,besides the pushing through the brakes..I had a few people tell me that I need to upgrade the brakes to dual piston calipers..
                    Time for better brakes.
                      Wow, Dr Phil lowered himself to tuning an LT1?
                        He will tune LT1s as long as they are 24x converted or you are really nice
                          That is an awesome time!
                            Yeah that's what I gathered after hearing his rant about LT1s
                              He would prob tune most anything with an LS pcm.
                                Actually I still have the Lt1 PCM..I do however have the LTCC conversion..Phil was actually impressed how well the motor ran and the hp #s it put down..
