Anyone stock 95LT1?
  • Anyone stock 95LT1?
    Does anyone have a stock tuned 95 LT1 I can come over and pull the tune from?
    I had to format my laptop and loss my stock tune. The tune on the car is slightly altered and I want to keep a copy of a stock tune for reference and if I have to flash to stock.
    Thanks.
    Originally posted by Yoshi94
    I think i have one saved on my external hard drive from my car I could email you (if i find it).
      Using TunerCATs or HPTuners?
        HPtuners does not support obd1, although boy i wish it did. Its a tunercat file.
          Thats what I needs then. GIMME GIMME GIMME!
            That is what he needs then, Preez Preez Preez!
              I found it. Yo Email Addy?
                SCREW YOU EMAIL BOTS!
                  I'd remove that email address ASAP because you will get spam bombed if a bot a picks it up
                    Thank you sir. Downloaded.
                        I am looking at the %Change to AFR at WOT tables. I understand how to set the target AFR for one temp but when I set it for 1 temp its obviously way off for all the other temps.
                        Example:
                        Coolant (44 degrees) = 26.6
                        RPM (4000) = .8
                        26.6+.8/100+1 = 1.274
                        14.7/1.274 = 11.53 AFR
                        Coolant = 23 (56 degrees)
                        RPM = .8 (4000)
                        23+.8/100+1 = 1.238
                        14.7/1.238 = 11.8 AFR
