02 Berger Fikse FM-5 Rim size?
  • 02 Berger Fikse FM-5 Rim size?
    Just wondering what rim sizes (Fikse FM-5's) were used for the 02 Berger Camaro's? I figured the fronts are 17 x 9.5's w/ 275/40/17 BFG KDW's.
    I'm just wondering if the rears are the same size or wider?
    Any help would be greatly appreciated!
    Brian
    2013 Stage II Nickey Camaro Convertible #10
    Special Edition
    Red Magnuson Super Charger w/a rear cog drive, ZL-1 fuel pump, Nickey cnc ported heads, Nickey spec. custom grind cam, Roto Fab CAI, Kooks LT's, No Weeds dual mode elec. diverters, Pedders eXtreme XA Coilovers, Pfadt ZL Spec sway bars, 20" AR Torq Thrusts wheels w/ polished billet Nickey centers, Nickey pistol grip shifter, upgraded 1400hp rear axles, 800hp @ the crank, 670RWHP w/613ft. lbs. of torque @11 lbs. boost! Check out album for pics!
    Every Berger SS I had seen appeared to have the same size wheels all around. The amount of lip showing on the wheels seemeed to be the same.
      17x9.5 all around
      88' Trans Am 350 TPI
        Originally posted by scholtmj View Post
        17x9.5 all around
        That is correct.
        — Thomas Jefferson
          A 4th gen was $46,560?!
