no spark no codes
  • no spark no codes
    35th ann V-6 camaro
    filled up with fuel, parked it at the house, got up in the morning and she didn't fire. it was cold in the morning, frost and what not, but i brought her to autozone after killing the battery and i got no codes (probably from dead battery).
    would a crank sensor prevent spark? i plugged a plug into coils 1-4, 3-5 and placed them on the dash while cranking.
    what about a cam sensor?
    cranks, pump runs, no spark, no fire
    HELP PLEASE
    ckkhiller@yahoo, live, gmail.com
    ckkhiller on xbox live
    ericf86@yahoo.com
    could be the ignition control module (not sure that car has one, i know mine doesnt)
      It has one, I've change it before... I'm told to check voltage atthe coils.. They are ontop ofthe ICM
        does the spark plug have to be grounded?
          How did you check for spark?
