After doing many searches/looking at oil system schematics I discovered this. I had to tap a fitting into this piece to get oil back to my turbo nut I don't see any reason you couldn't drill/tap a hole in this and plug it after. Just use a fluid transfer pump until you have 5qrts in and oil is flowing from the pushrods.
Hope this helps somebody. Its not absolutely necessary I have never primes my ls motor in the past but it couldn't hurt to have oil pumped through on 1st startup
Don't mind the dirty part either I will take care of it before final assembly.
