4th Gen T-Top Camaros: Do This TONIGHT!
  • 4th Gen T-Top Camaros: Do This TONIGHT!
    Seriously, you don't want this to happen to you:
    T-Top Flew Off while LATCHED AND Locked!
    Here's what to do:
    Originally posted by Dayton F-Body Association
    Courtesty of eboggs_jkvl on LS2 Forums.
    First, Take off the T-top
    Next, remove the 2 phillips head screws that hold the trim cover in place and remove cover.
    Next, take a 10mm box end wrench and loosen the 2 bolts holding the clamp. Do NOT remove the bolts.
    Now, put your T-Top back on, latch it and then slide the bracket adjustment as far as you can toward the front of the car. The bracket will slide on the T-Top mounting rod. I simply used a small screwdriver to do it.
    Then simply tighten up the 2 10mm bolts to secure the latch receiver in place, take off the T-Top and replace the trim moulding.
    thanks ill check that out.
    A convoy of imports= Alot of unessary noise
    Master ASE Certified
    Master State Certified
    Master State Motorcycle Certified
    GM Certified
    Winners Powersports
      what exactly is that procedure doing?
        it's making sure that the locking mechanism that the t-top's latch/bolts into are actually holding them in. Basically the one guy's bolt was fully extended out, but the mechanism in the A-pillar didn't "hold it" so it flew right off.
