Wiper pivot? What is this called?
  • Wiper pivot? What is this called?
    Hey guys,
    I've had a problem with my wipers for a minute, seemed the motor was working but nothing was moving. I found the problem today, the drivers side wiper arm...pivot...bearing housing? Well its frozen, but I don't know what to call it so I'm having a time finding a replacement.
    Its the actual swing point of the drivers side arm, like if you took the arm off and we're looking at the little spline cone, it's that, well along with the rest of the unit anyway.
    Does anyone know what that is called?
    Also, I am trying to understand the park mechanism, I believe when I shut the motor off it should go in reverse a little bit to park the blades. It's not doing that, so I suspect the wiper board is bad? any opinions on that?
    im not sure, but i have the whole assembly jsut sitting if you are interested
      Yeah, how much you looking to get for it?
        I had to replace that unit in my girlfriends G6 and in her car it was called the "wiper transmission"
        1998 Camaro SS Bullseye Turbo
          The linkage is called the wiper transmission.
            Thanks guys, I found a couple on ebay but that's about it, Just waiting to hear back from three honks to see if we can work something out
              sent you a pm back, i'll pm you my cell so you can just txt me. im not on here a lot
                Also if u need a hand installing the wiper linkage ( transmission ) I can give you a hand it's very simple
                  I appreciate the offer but i think I got it
                    i had a gtp once where the wiper would go up but not come down. Turns out where the arm bolted to the linkage the bolt (just the top is threaded, it has the grooves to hold the arm in place) had slowly stripped itself over time and wasnt locking so it seemed as though the whole thing was frozen but really it just didnt have any grip to turn itself. sorry its hard for me to explain as i have no idea what any of the wiper assembly parts are called... :/
                    94 Z28 - speed limit removed and shift points changed (previous owner did that,) tb bypass mod, cai, msd otvc wires,opti, and coil, pacesetter longtubes+3in ory all the way back to a flowmaster 40 (i know), a/c delete, z06 wheels 17x9.5+18x11.5 , ss spoiler w/leds, tints 20% in front 5% in back, halo projector and custom hid setup 10000k, purty motor paint, led fan switches (1 for each) custom interior (suede) and some carbon fiber and white leds, ttops, and 1600 watts in the trunk.
