check them all because if had something like this happen on a nother car and i replaced like $500 worth of parts and like a mounth later i was sick of it so i started taring into it agin and it was a stupid #6 wire that was not attached 100 % just a little of seperation and it did a lot of harm so i just now from experience double and triple check everything.. and i now its time counsumming but ya gotta do it or pay big buck to have a shop go through it..
if your MAF fixed it, then happened again, i would be very suspect of it... do you have a K & N or other oilled type filter? if so, remove it and the MAF, clean the MAF with electrical parts cleaner ONLY, do not touch it. replace the filter with a paper filter... change out plugs and wires... check the cat... if it's an auto make sure there isn't a prob with the trans that's making your head go crazy...
i cleaned out the maf with maf cleaner again, however i did not spray the cleaner directly on the sensor, just in the maf. didnt fix the problem. i was also puzzled as to why it fixed itself then went back to crap again so i thought it was the maf too but i guess not.
in the maf, not on the sensor? the problem occurs when oil jumps the gap between the wires(sits on top of the resistors and changes the resistance). You need to be sure that the wires are free of oil, the sides don't matter much.
1999 Turbo Trans Am WS6**Under Construction** Rear Mount Retired
Haters Quote "That car wont go faster then 10.50's" My response? You Lose!!
2015 Silverado 2500HD 6.6 Diesel
2010 Corvette Z06
"The SS looks like it could kick your ass if it wanted to, the WS6 looks like it's coming over to do it!"
