So my car ran great today when I brought it home to wash it up for woodward this weekend. When i got done washing the outside and engine bay I drove it around the block then pulled it in the garage to clean the inside. And when i got all done and ready to go put it back in storage till Saturday it wouldn't start it would only crank over. So i checked fuel and i checked spark and they both seemed good. So i was baffled. So i did a scan on the obd1 and a code 16 (low pulse resolution) and a maf code. But no idea what to do i did a little research and i guess its common when the opti's are on they're way out?...can anyone offer me any advice or guidance cause i dont know what to do except replace the opti and i really wanted to come to Woodward.
Help: Opti Fail Code 16?!?
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- 1999 BBM z28 Camaro
- Saginaw Michigan
- New Car Sales Consultant
1984 sport coupe red 4 cyl (Sold) -
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- Saginaw Michigan
Yea i always do and most of the time i use a power washer but this time i used just running waterOriginally posted by nascarnate326 View Postwait, you washed the motor?1999 z28 Bright Blue Metallic 1 of 10
It is pretty much common place to never was an LT1 with running water. I did this once and was very careful not to aim any water at the opti and it still went bad.Originally posted by Purple94Z28 View PostYea i always do and most of the time i use a power washer but this time i used just running water
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
well I think your out for the cruise, I would give it 3-4 days to dry out. go to www.shbox.com there is a trouble shooting proceedure for opti and ICMsigpic
