has anyone else deleted there cat... that has a 94.... and if so other then sound.... did it throw any codes??
exhaust cat...
exhaust cat...
1994 Z28...LT1, A4, Tune up-(2005) w/ MSD 8.5 wires, K&N CAI F2, Hooker exhaust, TB-bypass, clear turning lense's, cat delete/ 3"pipe install, J&M STB,90'degree silicone elbow, Royal Purple oil, MSD-blastercoil, current Miles~[130,000].. hawk pads,performance rotors.url]http://www.myspace.com/camerz2894[/url] -
i have a 95 with no cats. a 94 is OBD1 also which means there are no cat monitor sensors... therefore it wont throw any codes if you cut it.Originally posted by Camaroz2894has anyone else deleted there cat... that has a 94.... and if so other then sound.... did it throw any codes??-Joel
Joliusz28 is right. 94s have the OBDI so there arent any O2 sensors behind the cat. It wont throw any codes or cause any problems as far as your computer goes (cops might be another story). My 95 is the same thing and i ripped mine out about a month after i got it. Should make a slightly noticeable gain especially if your cat is old and clogged
No problems with your setup on that year. Id say cut it and put in a straight pipe over gutting it. Will sound pretty good after, louder of course.
hey
ok sweeet.... thanks guys....
Im with them, cut it! If you start to throw an O2 code you can get an O2 simulater from jegs i belive or if you know someone that tunes pcm's you have that parameter totally removed i think. soon as i get my headers im smashing the bricks out of mine (so it looks like i still have them if the vehicle is raised) and running o2 simulators. i want mine as loud as i can get it without it sounding like my exhaust is ran though a metal trash can.
A convoy of imports= Alot of unessary noise
Master ASE Certified
Master State Certified
Master State Motorcycle Certified
GM Certified
Winners Powersports
