throe out bearing noise.
  • throe out bearing noise.
    Ok my clutch and everything is new with 1500 miles on it and ever Sence I installed it the throe out bearing has made noise it makes me crazy I'm afraid that on a 7000 RPM pass its guna grenade am I the only one haveing this problem if so what is the deal with it .
    sigpic1997 firehawk # 115 6 speed. Its just a little ole LT1
    is the TB new?
      Originally posted by nascarnate326 View Post
      is the TB new?
      Yes it came with my clutch supost to be good for 650 HP also .
        Did you relace the pilot bearing? It could be bad causing the clutch throw out bearing to chatter.
          Yes that is new as well the only thing not new is the trans and it has 23000 miles on it its the origanal trans .
            You no it could be the trans . The reason I was thinkin it was the throwout bearing is because when I push the clutch in the noies is gone its only in neutral so its Probly the trans rattleing around I looked it up and other people have been mistakening the throwout bearing for trans noise so I don't no but it makes me want to have it gone thrue.
