I have excell so I would assume I can, where should I start with that?
I also thought it seemed like a lot of KR, I did not think I was really getting knock so I put in some 100 unleaded and it was the same.
As long as you are 100% sure you have the correct files loaded. Then you should be looking at good info. If you have the wrong files in Tuner pro then its not proper info. Where did you get your files?
You have mail.
Is the motor cutting in and out or just the log?
All I have is the ee auto file from their website.
Did you watch the dashboard view of my datalog? It would cut out to nothing then go right back.
So should I get an LT4 KM?
I would pull the ECM and get the number right off of it and look at the chip to see what .bin is on the prom. then you can be 100% sure you have apples to apples.
