brand new opti, car had a hesitation off idle and when I would shift from WOT one gear to the next it would stumble as soon as I got into the new gear, take a few seconds and then come back on full power.
You can put the opti on wrong on a 95 -97. there are 3 funny shaped openings and then there is the round drive hole. we actually installed the opti in the wrong opening and it clicked right in on B's car. He was 180* out so was more obvious. You might be 20-35* out and it could be problem. Also old opti might of been fine and you had other problems and new one with wires changed symptoms.
Up until this happened to us we thought the round drive pin would NOT go into other holes. But, it will, and drive can be anywhere and mount holes will line up.
I honestly will never install an optispark again without being able to hold onto the rotor (meaning the front case is off) and ensure the hole lines up perfectly.
95 vented opti. The problem with them, IMHO, is that when you take them apart one side of the rotor is heavier than the other. So you can position the hole, let go of the center rod while you go to slide it on, and the rotor can spin around on you while you're sliding it into position and you wouldn't know it. That's what happened to me. Mine slid on very easily, I didn't have to use any force, yet it went into the wrong hole.
If you dropped the MAF, then yeah I'd start there. But Optis are known to not like 6k RPMs either. Wish your car was a 95 so I could hook it up to my diagnostic scanner and help with datalogging. The tool you showed earlier -- is it yours or rented? See if you can hook it up to someone else's and then compare readings.
BTW - the MAF reading you posted above is spot on for idle.
Originally posted by Injuneer's Website
Note - to convert grams per second to pounds per minute:
grams/second = pounds/minute x 7.56
Example: 30.0 pounds/minute x 7.56 = 226.8 grams/second
At idle, the air mass flow will range from as low as 6gps to as high as 10gps. If you reading is suspiciously low, you may have a vacuum leak. If it is suspiciously high, and the idle speed is correct, it's most likely a "faulty" or "miscalibrated" MAF. This problem is typical of "home ported" units.
At WOT, the peak air flow in a stock, normally aspirated engine, with a 5,800rpm rev limit will be about 240gps.
Your picture above puts the MAF reading at 8.6148 gm/s. My dad's at idle is around 7gm/s.
Baring any unforeseen issues....my car runs perfect.
Changed the MAF with one out of a 95 corvette and it revs, starts, stops, pulls, sounds, idles just the way it should. My car is soooo smooth now. No delay in the power.
Kind of wondering of the opti was ever my problem now.
Anyways I learned an opti is NOT that hard to install, and that my Chandler Motor Sports opti works fine right now with 22 miles on it. Lets see how long it lasts. Thanks to everyone that helped.
