How much preload are you running on your LS7 lifters? My internet search resulted in answers ranging from .030" to .120" with .050"-.060" being the most common.
LS7 Lifter Preload?
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
The way I have adjusted preload is you lightly turn lifter rod untill you feel very slight drag. then tighten nut another half turn. You really don't have a clearance like solid lifters. look in sticky note I'm sure someone has posted a proceedure to adj.sigpic
