Will th350 bolt up to an ls1?
  • Will th350 bolt up to an ls1?
    What do i need to do to get a th350 or th400 work with my ls1 in my 98 camaro z28?
    sigpic383 ls1, th400, moser 12 bolt
    trans will bolt up, will need a ls1 specific converter and will need a different crossmember for trans mount.
    When in doubt, Whip it out !
      You will need
      Torque Converter
      Flexplate
      Shifter
      Driveshaft
      Crossmember
      Dipstick Tube
        alright another guy not afraid to ditch OD! Man card approved!
          Don't you need a adapter for the crank I've done sum reading and they used a crank adapter seems like they would just make a flex plate to fit .
            There are a few options, TCI makes a flexplate around $200+ or they make a spacer and longer flexplate bolts. I don't remember the PN but, I picked up a flexplate, bolts, and spacer for about $50 from GMpartsdirect.
