My oil pressure gauge is showing really low pressure, almost none at idle and wouldent go past 20 at idle. The car runs fine and everthing but i need to know where you attach a mechanical gauge so i can verify it's just the oil sending unit.
Oil sending unit
InActive Member
- February 27th, 2006
- 962
- Drew
- Drifter.
- Grosse Pointe Woods
- Professional Racer/Builder/Tinter
LT1's just have notoriously low oil pressure. Not a bad idea to get a mechanical gauge on there, but usually it's nothing to worry about.
SpeedDetroit Speedshop <Owner> Detroit's Only True Grassroots Speedshop
http://gasfed.blogspot.com/
Originally posted by KuruptWS6spdAnd yes my box is ALWAYS this clean
there's somthing wrong though because even when i reved it to 4k RPM's i still was under 20 PSI, i figure it must be the sending unit (hopefully) because i just can't see an well maintained car having oil pump failure at 85k milesOriginally posted by Insomnya3AMLT1's just have notoriously low oil pressure. Not a bad idea to get a mechanical gauge on there, but usually it's nothing to worry about.1996 CAMARO Z\28 M6
