I have searched around and all i can find is threads talking about removing the side skirts off the stock ground effects. Right before i put my car away for the winter i had to turn around in a dirt driveway and somehow hit the small gfx on the front passenger side. It flexed and the paint came off in a huge chunk. The was no other damage. I want to remove the body kit piece in the front but i want to make sure i can get it back on after i get it repainted. Any ideas?
Stock body kit removal
2000 Z28 - Cammed/Stalled/Intake - Collision With a Tree Mod - Totaled
2005 Grand Prix GXP - Sold
2000 SS - Sold
2011 Ford Taurus limited - Time for a practical car for a bit
i have the RS body kit
2000 SS - Sold
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- 1999 BBM z28 Camaro
- Saginaw Michigan
- New Car Sales Consultant
I would just tear into it...and go from there1999 z28 Bright Blue Metallic 1 of 10
If I remember correctly removing it will leave several holes in the body, I think it may be riveted on.Doing less with more
I think you're right JeffOriginally posted by DETROITMUSCLE View PostIf I remember correctly removing it will leave several holes in the body, I think it may be riveted on.
http://www.ls1tech.com/forums/appear...-body-kit.htmlLast edited by Lucky SOB; February 15th, 2011, 12:46 PM.2000 Trans Am l 1967 Firebird
InActive Member
- November 18th, 2007
- 439
- Mike
- 2002 Camaro LS1 M6
- Ortonville Michigan
- Fork lift repainter
I've taken my kit off before.. It has riveted plates that the top lip of the body kit slides into and then the body kit is held in place by I think 3 or 4 push in clips from underneath. There are also 2 plastic rivets in the fender area. The side skirts has the same plates that the lip of the kit slides into and then it is held in place by screws underneath, it also has 2 plastic rivets in the front fender. Very easy to take off and put back on.. If you plan to take it off and keep it off there will be holes in the rocker panel and front bumper from the plates that are riveted on. The spoiler has double sided 3M tape plus 3 holes in each quarter panel.
i just want to take off the little front part so i can get it repainted and then i will throw it back on. Thanks for the info i may try to take it off tomorrow.
2000 SS - Sold
InActive Member
- 439
- Mike
The front pieces are really easy to take off.. Like I said there's about 3-4 push clips underneath plus the 2 plastic rivets in the fender. Good luck and if you have any other questions drop me a PMOriginally posted by Dewman View Posti just want to take off the little front part so i can get it repainted and then i will throw it back on. Thanks for the info i may try to take it off tomorrow.
