I have a few jar style pullers.
I just was not sure if it was that easy.
I got the center bolt out easy with an impact, the engine it not in the car so all of this should be easy.
Should be a cakewalk then. Just make sure you have enough threads of the crank bolt engaged so you don't chew them up. I broke my 3-jaw a few times pulling mine...cheap Harbor Freight stuff.
Smack it a bit with a rubber mallet then use a 3-jaw puller?
rubber mallet?? try a sledge hammer. just dont hit it in a way that pushes the crank inwards. (Ok, a regular hammer should do the job, but believe me youll need to do some persuading...)
Go to Oreillies or auto zone they rent a hub puller balancer puller set. zero dollars
Absolutely!
No Hammering on the crank!
3 jaw pullers can screw up the balancer. If you use them, go inside the webs, not on the outer rim of the balancer.
If this is the option you use, very light heat applied with a torch to the crank snout and balancer interface can help things along. Don't get it super hot - you don't want to melt the front cover seal out.
Do you want me to bring the few pullers I have?
Buy a new balancer bolt as well. It's a torque to yield fastner, and you have to give it 150Nm of torque plus 114 degrees of twist.
Chances are, if you use the old bolt, it will be stretched already and you'll snap it off in the crank.
Do not to use hammer, go to reaillys get harm puller zero $. and be sure to use it to put it on. if you beat it on you can screw up crush bearing on crank.
