dies when wArm usually won't start when warm
  • dies when wArm usually won't start when warm
    93 z28 car runs great until warm then stalls, it will fire back up for a sec. everyone inawhile until cool?
    O2 sensors?
    Used to own a Firebird.
      I tried that
      I tried that already, could it be the vats?
        100% not vats. VATS wouldn't let the vehicle start at all. It won't even crank.
          Dare I say... the opti?
            would Rpm's jump?
            I don't know much about opti at all but would rpm's jump around before stall if it was the opti! I hope it's not. any other info ??
              Tps?
              Clamaped up tighter than a 15 year old on her first prom date...
                i say... the dreadful opti.
                97 TA AI 355
                2012 Jeep Patriot
                  did you try fuel filter? check fuel pressure on rail. maybe a coolant temp sensor?
                    fixed!!!
                    it wAs the opti went with Delphi running great also did the crank seal anyone recommend any inexpensive performance mods/bolt on"s
                      ahh another 93 owner! before you do any modifications you should make sure the car runs well, some times a tune up can be like a performance mod.
                      Most people agree headers are a good mod performance wise per dollar, also a cold air intake/LS1 swap might not be a bad idea.
                        like Brian said, headers and 3.73 gears in my buddies 93 and that car ran like a freak. that was also behind an auto trans. idk what your working with.
                          Thats because 93s had a different intake manifold and different alternator! bank injection = factory freak lol
                            lol i honestly cant explain it. it only ran a 13.5 at the track on street tires but man i dont think i saw that thing loose. had to be that and speed density lol
