Anyone got eBay headers?
  • #46
    uhh, since when does hooker make a stainless longtube?
    I believe I've seen SS LS1 Hookers, but not LT1
    • #47
      get some longtubes with the new motor, you'll thank yourself later.
      • #48
        Bought my long tubes this morning. Came out to $300.00 for headers, y pipe, gaskets, clamps, and shipping. I expect the install to completely suck, but it should make my car sound better, and have a bit more power. Still need to get O2 extensions. They are the LPP style I believe. I plan on keeping my I pipe and flowmaster for testing. If I dont like it, I will just do the GMMG clone that I wanted last summer.
        • #49
          do not use the gasket they provide. for another $30 you can buy the percys dead soft aluminum and they will not blow out or leak. trust me on this, do not use the gaskets that come with those headers
          • #50
            or fel-pro 1406(?) is what Ive had for 5 years with no leaks and ive reused them several times.
            • #51
              the fel-pro's are very good too. But I have used the percy's seal 4 good dead soft aluminum and they are the best gasket I have ever used. If you have a header leak it will cause havoc with the car.
              My mustang had a header leak due to me using those gaskets they supplied and they were blown out enough so when I would take it out of gear it would actually stall the car
              • #52
                i used the same one and never once had a problem with mine... tried some other ones and they never worked as good
