Apparently buying torque arms that fit is also for pansies! Honestly after doing this im not sure how anyone goes lower than i did without major problems. Hopefully this is good for another inch of travel or so before the "self-clearancing" feature kicks in
I also i think i have the exhaust clearance issue resolved... Need to bolt it up and see. I am going to be tucking the mufflers up higher than before
Lastly, an updated picture of free suspension components. (i have a front sway bar in the attic also). how do i still have these tubular a-arms??????
Did you have to disconnect the front sway bar to get the front shocks out?
I was having a fun time trying to get to the bottom of the link through the arm, I bought new links for the front and will probably just cut the old ones in half.
Originally posted by Yoshi94
Not sure if i had to or not but i did and it at least made it a lot easier. Many times the original links are going to shear off instead of disconnect, but the next time will be easier at least.
Edit: if youre having trouble getting links through the arm disconnect it at the chasis first so you can pivot the whole thing around to get a better angle on the bolt/nut.
Probably still have those control arms because they're non-adjustable. Although for free, anyone with stockers SHOULD get those. If I was paying money, though, I'd pay to get the adjustables.
If these things don't go soon, Joel, I'll gladly take a run up Romeo Plank and get them from you. I know Spencer had dibs, and then Rolo. I guess put me in line after him
close to 16 and groesbeck? i need to stop by joels real soon for some stuff i could grab them for you if you wanted. might save you a little time.
