Where ac was. No way in hell id delete power steering
Project: PBR-Built Z/28
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Ah thats right you want to AutoX it. Come on it would be fun not having PS and trying to AutoX. "Um why is he 500ft off the course?"Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
text me a price for some stuff. lolOriginally posted by kammi10 View Posti have a set @nascarnate326
my cars going to be back together soon one way or another.
Joel, did you ditch your ac parts?1998 Chevrolet Camaro Z28 - 6 Speed
Yes, i sold the complete system to SoulTerror a couple years back.
Also I just bit the bullet and bought a rear sway bar. gave up trying to find a used one, i guess nobody buys them. Spohn 22mm solid chromoly to match my front bar. As soon as i get it and my fuel lines are permanently routed ill be pulling my rear suspension apart one more time to paint everything nice.
BTW, salad shooters also make a great stackable step stool for climbing into your car while its up on your hoist
Lurker
- March 13th, 2010
- 3476
- TJ
Speaking of which. What is the stock rear bar size? I Need new bushings and end links for the rear. Also need new end links for the front.
Was thinking of getting Moog or Polyurethane ones.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Actually I just found they had a 25mm version of the same bar, so I am changing my order to that. Stock sizes are 30 / 19mm. The spohn front bar I already have made a HUGE difference. Probably one of the best upgrades ive done for the money.Originally posted by Fox Slaughter View PostSpeaking of which. What is the stock rear bar size? I Need new bushings and end links for the rear. Also need new end links for the front.
Was thinking of getting Moog or Polyurethane ones.-Joel
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
are thirdgen rear bars the same? i might still have mine laying around.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
Post Whore
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
I have a third-gen rear bar laying around too, 24mm I believe. Was under the impression that was too big for a handling setup though, throwing the balance off and such?
Saw Joel's car yesterday while he was kind enough to buff out Angie's front bumper after I hit a construction barrel. His car looked ****in awesome and the stance was mint.- Brian Meissen
Lurker
- March 13th, 2010
- 3476
- TJ
Sucking up to get some discount on the buff job eh?Originally posted by meissen View PostSaw Joel's car yesterday while he was kind enough to buff out Angie's front bumper after I hit a construction barrel. His car looked ****in awesome and the stance was mint.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Nah, we paid him off for the buff job with some Jack and coke.
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- 1999 BBM z28 Camaro
- Saginaw Michigan
- New Car Sales Consultant
Cool man at least it isn't an extensive list to be able to drive it this spring!Originally posted by JoeliusZ28 View PostAt the point fuel lines are installed and working, just modify the exhaust to clear the torque arm, and fix the passenger window and then itll be driveable again. Key word driveable, still tons of other things on my list i probably wont have time for.
Next thing i will probably do is change all the fluids, relocate the alt and install the power steering cooler.1999 z28 Bright Blue Metallic 1 of 10
PM me what i owe ya sir!Originally posted by mcalus View PostRolo should have your stuff and things
