Nothing, Absolutly Nothing.
    No easy way - just trial, error, blood, sweat, and a lot of muscling.
      I got it on. Went on kinda easy. Is it bad to run open headers? I wanna go to the Harper Cruise.
      Originally posted by Yoshi94
        Yes and no. Open headers will cause your O2s (if they're hooked up at all) to read lean because it's going to be getting oxygen from the headers being open... Lean running o2s will make your engine dump more fuel in.
          don't run open headers, not good for the O2s as Brian mentioned and the car will not run right.
            Well if I'm not mistaken dumping more fuel in will make it more rich which just wastes fuel correct? Or what if I just bolted up the cut out pipes?
              running too rich or too lean is not a good thing. Too rich will wash down the cylinders over time and most likely foul out your plugs pretty fast. Do it right and finish the exhaust, just my $.02
                if you really want a quick solution you can run a foot or two of straight pipe and it will be alot better.
                  Or If I can get some hands to help me mark up the exhaust when my neighbor gets home I'll see if he will tig weld it all together and just bolt it up
                    put some kind of exhaust on it. That car is too nice to have any more problems.
