12" or 24" extensions?
New Exhaust Coming.
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Lurker
- March 13th, 2010
- 3476
- TJ
Alright um how did you end up shielding the fuel lines?
http://www.jegs.com/i/JEGS/555/14905/10002/-1
This the EGR block off?Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Fyi you won't need to worry about the EGR being blocked off throwing a CEL, but the AIR still will I think.
Honestly I just got creative with some zip-ties and i flipped one of the fuel-line mounts over to give me more clearance. I havent had a problem without shielding but i should probably add some anyway ... lol. This is why i carry a fire extinguisher at all times! My plan is to reroute the fuel lines entirely to the driver side this winter.Originally posted by Fox Slaughter View PostAlright um how did you end up shielding the fuel lines?
This the EGR block off?-Joel
Interior Whore
- January 21st, 2008
- 6380
- fred
- 1996 Camaro z28
- U.P. and over you.
- united states coast guard
my egr throws a code for non existance but my air doesnt lolwishing i could drive like joe and the atm squad
if you can do the even the most basic fab work you can make your own block off plates. I made all of mine out of sheetmetal. Just use the gasket that is already there as a template, and then reuse that gasket with the block off plates you make.-Joel
Lurker
- March 13th, 2010
- 3476
- TJ
Maybe I want a fancy shiny one that says jegs!?!??Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Put a mirror on your firewall that way everyone can see itOriginally posted by Fox Slaughter View PostMaybe I want a fancy shiny one that says jegs!?!??2015 Silverado
Lurker
- March 13th, 2010
- 3476
- TJ
Anyone wanna come help me this weekend? Beer and I have a pool haha, and 2 out of my 3 PS3s are here so we can get some gaming on Call of Duty 4 MW or Call of Duty MW2 or Killzone or FEAR2 or some NHL10 anyone?Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Lurker
- March 13th, 2010
- 3476
- TJ
So when I do my header swap, they finally come tomorrow. How do I block off of the A.I.R? Just remove them and cap the tube with a vacuum cap?Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
yep. im busy this weekend but if you do the swap this coming week i might be able to lend a hand.-Joel
