Longest Spark Plug Change Ever
  • Longest Spark Plug Change Ever
    Wow, these LT1s are horrible for changing the plugs. It takes me like 15 minutes to change plugs on a car if that. This car took me 2 hours to change 6 plugs!!!! Jesus Christ! They are horrible to reach!
    Just thought I'd go on a rant.
    Originally posted by Yoshi94
    I'm dreading the day I have to do mine again...there's one that can only be taken out with a wrench on a socket
      Guess its you. Took me 45 minutes on a buddies car. I didnt' think they weren't that bad. Not as bad as some I've seen out there. I've done cars where you've had to disconnect engine mounts and rock the engine.
        Get some long tube headers. It took me like 20 minutes to change the plugs on my LT1 after I installed the Pacesetter LT Headers.
        Nick H.
        Current MIFC Vice President
          Same here, takes me about 20 min with my BBK shorties. Yeah, deffinately get headers. I did mine when I did my first tune up. Eric L
            Why did you change the spark plugs?
              Never did an LT1, but I can tell you an LS1 is not any fun either.. I finally learned the secret last year.. I can change mine in 30 minutes or so now...
                Just be thankful you don't have an f150 with the two piece plugs. they can take 6 or more hours if/when you break one off.
                  Doh!
                    o yes, you have to love changing plugs on our motors! iv changed mine 4 times within 200 miles on my new motor.. it sucks, but owell. drivers side is really easy but passenger.. not so much..
                    97 TA AI 355
                    2012 Jeep Patriot
                      Pass side sucks..
                        I don't think it's that bad, but then again I'm pretty skinny. Pass. rearmost plug is removed easiest from the bottom.
                        Used to own a Firebird.
                          x2 i couldnt imagine how much fun a stock ls1 would be lol with all the air and egr crap on the pass side. i can change mine in about 30mins as well now. removeing the pass side coil packs make it 100x easier
                          The LS1 or Go Home Crew
                          ASE master certified
                            I break the hard ones loose with the ratchet and then attach a broken plug boot to the plug to unscrew it and screw it back in.. Works like a top on all the hard plugs... I do em all from the top..
                              I've got fat hands and I can do them all easily from the top just gotta climb up onto the battery and reach back there. Once I start spraying I'll bet I can do them in 10 mins.
