Strut Tower Brace HELP
    When I removed my bar and went to put it back on I ran into the same thing. Looks like you have it bolted down on the passenger side already. What I had to do is remove the nuts on both sides and try to drop it on both sides at once. That way its not trying to go on all cockeyed over the other side. Dropped right on in my case. Try that....if that makes any sense to you.
      I tried that with mine, didn't work. That's why I went elongated.. Craig, you are correct, I just never bothered to correct him(Shock tower)..
        The V6 brace kind of angles to the firewall some so that it goes behind the alternator. V8 is straight. In my case also, I did the "Tom" install.
          should be a real easy 4 bolts looser 4 bolts tight install try prying the bar to the holes bc it dont look like its off by much
          "You can get a lot more done with a kind word and a gun,than with a kind word alone."-Al Capone
          "Ever since we was kids,we always knew that people can be bought.It was only a question of who did the buyin' and for how much"-Charlie "Lucky" Luciano
