I got a Z28 95 6speed 95K miles on Friday, started fine. Saturday it was raining all day and I went outside and the car won't start. I think its a wet opti. Today its raining again, still no start.
Tell me its a wet opti and it just needs to dry. Thanks
Originally posted by Yoshi94
did you drive through any puddles that may have splashed up? being parked out in the rain shouldnt have done anyhting unless the hood was left open, or you were spraying the engine down with a hose (a big no-no with these cars)
but there isnt much else it could be - everything is like new on that car. do you hear the fuel pump priming when its keyed on?
Yeah listen for the 3 secound prime when the key is first turned on. If you cant hear it, Find the fuel pump relay, and switch it with another relay. And listen again for the fuel pump prime. If still nothing. you got a fuel pump problem. If you do hear the fuel pump or get it to work, check for spark.
Yes he checked all of the fuses and can hear the fuel pump. The fuel pump is brand new as well. The ENTIRE ignition system is new - opti, plugs, wires, coil
Just dont mess wiht the car anymore until you have a dry and sunny day. If you are messing with it in this crappy weather its gonna make it worse. Once we get a sunny day leave the hood open in the sunshine.
The rain isn't going to cause it not to start to start. The car was driven year round before you, and had no problem starting in torrential downpours/ snow/ fog /whatever
Yeah its a nice car. Sorry been feeling kinda crappy thats why I haven't replied. I had the hood popped the hood probably like 5 times Friday night it wasn't raining. I came home around 12 O'clock wasn't raining yet. Shut the car off went inside. Got up around 10 and it was raining, decently. Went outside to run to the store tried to start and no go.
Yeah my plan was to when I get off work tomorrow at 4:30 come pop the hood and let it sit till the sun goes down and then try to start her. Still haven't come up with a name for her yet.
Okay, I'll ask again. Why would the opti be wet? Even if you had the hood completely open there is no way it should have gotten wet enough to cause any issues. Only way you could harm it would be to spray it directly with water. You didn't go thru a carwash did you?
