No-Go Camaro
  • #61
    Originally posted by sman View Post
    Gotcha, just from reading I assumed you were just cruising down the road. How many miles on it? Were you spraying? Stock internals right?
    Yeah, stock internals. The car was sprayed before I got, then I sprayed it with about 3 15lb bottles. The car has 88k. The thing has not been pampered by the last owner or me. I wasn't spraying. The bottle wasnt in the car. I think nitrous is a blast, but I'm not using it anymore. Thats the reason I went through 3 automatics, 3 flexplates, 2 rearends and now this is more aftermath from it. My nitrous has been sold.
    • #62
      How big of a shot?
      • #63
        well even if the chain did break/stretch and pop off the top sprocket is connected to the camshaft and that should spin freely at all times. I'm guessing your going to need much more work done that your expecting
        • #64
          Exactly what I was thinking....
          We can rebuild him, bigger, and stronger!
          • #65
            Too bad I'm in Tx.
            • #66
              thinking about this some more maybe you bent a pushrod or broke a spring? Have they pulled the valvetrain yet?
              • #67
                No, its still together, He told me it was going to cost $3000 to do the heads, cam and crap so im gonna roll the dice and just have the chain replaced, and hope its ok. Right now I don't have $3000 to put into it. The car might end up in the for sale section soon, or just part it out. I bet I get more doing that. This whole thing sucks.
                • #68
                  Dang, that does suck. We'll keep our fingers crossed for you and your ride.
                  • #69
                    nice ride
                    • #70
                      Good luck man... Hope it works out for you!
                      • #71
                        Should have it back next week. Hope none of the valves are bent.
                        • #72
                          also found out thr car has an LS-6 block.
                          • #73
                            Mine does too... Good luck on the fix!!!
                            • #74
                              I'm waiting, just a few more days
                              • #75
                                Keep us updated John, I'm curious on the fix.
