couple ?'s
  • couple ?'s
    ok.... 1st ? is...... is it safe to used carb cleaner on the TB....? the inside pretty dirty... and 2nd ? is what do u guys use to remove the long tube lookin thing that hangs down on the intake elbow..?? i wanna remove it for space and put something else there ??
    1994 Z28...LT1, A4, Tune up-(2005) w/ MSD 8.5 wires, K&N CAI F2, Hooker exhaust, TB-bypass, clear turning lense's, cat delete/ 3"pipe install, J&M STB,90'degree silicone elbow, Royal Purple oil, MSD-blastercoil, current Miles~[130,000].. hawk pads,performance rotors.url]http://www.myspace.com/camerz2894[/url]
    Not sure if carb cleaner would be safe to use so i went to the parts store and got some that was for fuel injected engines, said it was sensor safe. Seemed to work good to cause man was it dirty! as for your other questions i will let one of the others answer.
      As for the secound ? that would be your Resonator tube is what I'm thinking your talking about U can remove it I would recomend getting a kit from Summit or jegs. There under Intakes & boxes at Summit. They come with new Elbow, Seals, and every thing els u need.
      I'm young, speed matters.....
      1996 Firebird Formula
      BBK 58mm Throttle body
      SLP cold air intake with Trick Flow Elbow
      Hooker Long tube headers
      3" Flowmaster exhaust
      Spohn Panhard bar
      3.73 rear gear
      Custom tuned by JET DST
