Hey guys, I figured I should probably address these problems first but I've noticed that after getting off the highway when I've been driving for a while my idle will be at like 1500rpm when I'm at a light or if I have the clutch in, starting to think maybe it's TPS but if I shut the car off and start it up again it usually solves the problem. I've also had problems with grinding going from 3rd to 4th intermittently, I think that it might be that my trans mount is screwed or an adjustment in the shifter (or at least I hope). Thanks for any help.
varying idle, odd shifting. LS1/T56
Throttle follower setting?
The 3-4 grind usually happens soon after startup and only on cold days, it didn't happen earlier on in the summer and I haven't been beating on the 3-4 shift at all. I used to have problems going from 1-2 if I brought back the shifter and it was too far to the left. Where exactly is the bleeder screw to my clutch master cylinder?
Used to own a Firebird.
