help quick doin install!!
  • help quick doin install!!
    ok guys broke the trans mount at the dreamcruise and got a new one , installing it right now... here is what it looks like... but is this the right mount for the year?? cause i cant get the crossmember back on ?
    1994 Z28...LT1, A4, Tune up-(2005) w/ MSD 8.5 wires, K&N CAI F2, Hooker exhaust, TB-bypass, clear turning lense's, cat delete/ 3"pipe install, J&M STB,90'degree silicone elbow, Royal Purple oil, MSD-blastercoil, current Miles~[130,000].. hawk pads,performance rotors.url]http://www.myspace.com/camerz2894[/url]
    where is what it looks like I dont see anything
      ahh man that sucks it didnt show.... but i dont have the pics anymore now.... :/
        well, i'm not see'n anything either...but my CrossBrace has 4 bolts holding it on...2 on the drives side, 2 on the passanger side, and then 1 in the middle that holds the TransMount/bushing....
        i found it's easier to get the 4 crossbrace bolts holding it up, but not tight...and then kindof wiggle the mount around to line up the trans mount, and then tighten all 5 of them once you get 'em all started....also try wiggling your trans some, it might move enough to get stuff lined up a little?
        1998 Camaro SS Bullseye Turbo
          Crossmember shouldnt be to bad to get back on. Did you go with a solid mount? Rather then a rubber one? If everything fit properly..i would say it would have to be the right one. Hope you figured it out.
          1999 Turbo Trans Am WS6**Under Construction** Rear Mount Retired
          Haters Quote "That car wont go faster then 10.50's" My response? You Lose!!
          2015 Silverado 2500HD 6.6 Diesel
          2010 Corvette Z06
          "The SS looks like it could kick your ass if it wanted to, the WS6 looks like it's coming over to do it!"
