Hey guys,
Disclaimer: Sorry for the book!!lol
So I bought a t56 online from a moderator on Ls1tech. He has 87 itraders, all positive, so I felt comfortable buying from him. He had a t56 with 22k miles on it since rebuild, pro 5.0 short throw, new stock clutch, flywheel, master, slave, and crossmember. I got it all for $1200. Note, Slave and master DIDN'T go in. Original are working great, why chance it. Trans gets here, put it in, put it in reverse to back out, let the clutch out and BANG griiiiiiiiiind. WTF!?!? Yank it out of gear, calm myself down, put it back in, same thing happens. So, after trying to use reverse I came to these conclusions.
-When you put it in reverse, it feels like it only goes about halfway in to gear
-If you try to let the clutch out without pressure on the shifter, it bangs out of gear
-If I keep pressure on second gear and sllllowly let out the clutch, it will pop really hard and try to buck out, but the pressure of my hand shoves it into gear. After I get it into gear, all is well.
-If I put it into 5th and then reverse REALLY fast, sometimes I can get it all the way into gear. This is pretty rare tho.
-ZERO problems in any other gear. Rest of the trans feels great
Now, I've been doing everything I can to avoid using reverse for the past week. He has been trying to find something else wrong the whole time.
-First, he thought my hydraulics had air in them. I told him, NOTHING was changed on the hydraulics, but just to be sure, I found flat ground, put the car in 1st, clutch in, and revved it to 5k. Didn't move an inch. Okay, clutch is disengaging, but just to be sure there isn't air in the line, I pumped the clutch 15 times and tried reverse.... no dice.
-Next he thought my reverse lockout solenoid was acting up. Verified it was working correctly by shutting the car off, trying for reverse, won't go cause its locked out. Turned key to the on position, lockout solenoid works correctly, now letting me into gear.
-He still thinks it might be faulty, so I check the fuse under the hood, thats fine. Still thinks it might be bad, so I replace the solenoid with my old one, still does the exact same thing, like I expected, since the solenoid only effects the gate, not actually getting into gear.
-Re-adjusted the shifter stops to ensure they weren't causing issues, even tho 1,3,5 all work fine.
So, I pm him telling him all this, he responds asking where the clutch engages. I respond almost exactly the middle of the overall travel of the clutch pedal, he responds saying I need to bleed the hydraulics. WTF?!?! No, I already ensured that that aren't any issues with the hydraulics.
Now, anyone have any other suggestions that it could be? I'm 95% sure its just a worn reverse gear, but he says his buddy he bought it from said it was fine, so it must be now. So, anyone have any suggestions on what else it could be? Or how to deal with this guy? I'm thinking about just telling him to refund me $300 so that I can get it fixed. I mean, I sure as hell wouldn't have bought the trans for that amount if I knew reverse was ****ed
