Got a new best time of 11.94 @ 117. Still getting 1.8 60's. Clutches are wore out in my rear end or somethin only one wheel is spinning in the burn out box. Changes I made since the last time there are adjustable LCA's, relcation brackets, took the y-pipe off, and 110. Note this is on only 5 psi and a stock converter
Went back to the track
get a converter and you won't need race gas to go much faster
very impressive.
Nice numbers Ricky, keep it up!sigpic
Glad to see that its running better Ricky. I'm assume that all the issues have been worked out?
either one will handle loads of power, especially through an auto car. What gearing do you currently have and what do you plan to have in the new rear?Doing less with more
I've got 3.73's now, the new rear I'd probably go with 3.90'sOriginally posted by DETROITMUSCLE View Posteither one will handle loads of power, especially through an auto car. What gearing do you currently have and what do you plan to have in the new rear?2015 Silverado
