Having an Issue
  • Having an Issue
    Hey all, I have to prime my car twice for it to start right up.. I changed the fuel filter and checked the pressue.
    On the first key on 0 PSI on the second 40 or so I cant remember exact.
    Whats going on here lol fuel pump or what? I heard of this before too anyone experience this?
    I have the same deal with my Camaro and i have the 3800 series 2. any info would be awesome!
    DraftKid
    The best part about buying new tires is burning the old ones the day before
    1996 RS 3.8L ... for now
      Maybe your relay is going bad?
      Did it just start doing this?
        what relay... where can I find It?
          Fuel pump relay - it should be under the hood, or it was in my 3rd gen.
            if it was the relay, would the pump not prime or pump?
            DraftKid
              if its the relay it would do nothing so it could be going bad but at the same time my friends 4th gen camaro will crank and crank for like 30 seconds then start and his pump is going out so if i were to guess i bet its the pump but i would test the relay to be safe
                I believe the relay is in the kick panel on the 4th gen. Not sure though. Check the wire diagram I believe the VATS picks the relay. So the problem could be associated to the ignition switch also. Easier to check all this 1st, than just replace fuel pump.
                  Are you saying that your fuel pressure was 40?
                  I think the highest fuel pump ratings I've seen were 14...most are in the 7ish range...
                    nono - 4th gen fbody fuel pressure is 40 at the rails, upwards of 50 at cruise.
                      Ah, gotcha...I was thinking pump pressure...
                        Have you noticed any problems while the car has been running?
                        Your pump should hold a steady pressure and shouldn't fall off.
                          No, once its running its a champ, just on the first start after its been sitting
                            fuel pump relay is under the dead pedal inside the car.
                            check there for a clean signal from the pcm and battery.
                            the grey wire goes to the pump/level sender
                            orange is hot
                            green/white is pcm signal
                            and red is the fuel pump prime connector.
                            add power temporary to prime the pump
                            http://www.camaroz28.com/forums/show...rime+connector
                            since you say it run fine, i don't see it being vats, should prevent you from even starting the car
                            if you are gonna stick with the lt1, hopefully its a 94/95 pcm which is obdi and then you can get tunercats and a cable for 150 bucks. well worth it...its not vin or pcm locked. i still have the program, but no cable
                            Steve.
                            http://s270.photobucket.com/albums/j...monte%20carlo/
                              i would bet its the pump my friends car runs great when started but his pressure is LOW
