Took my car to Ubly today, ran a best of 12.08 @ 115. I was pretty happy seeing as I'm only running 5 psi and have a small, small converter. Car didn't hook very good however. I want to get a line lock and some LCA relocation brackets and I want to see if I can get into the 11's with this set up.
First time to the track
Originally posted by JoeliusZ28If you need 6 and half grand to break your tires loose you shouldnt be attempting a holeshot. -
Not a clue. It was on the car when I got it and havent touched it. What's reccomended?Originally posted by c0ncEpT View PostWhats your pinion angle set at?2015 Silverado
What do you guys reccomened to get the 60's down? Will the LCA relocation brackets help me out? Should I just keep playing with my tire pressure and how much I heat them or do you have any pressure reccomendations?2015 Silverado
I don't know the size of your tire, but you probably will want to run around 12-13psi. I've also heard the re-location brackets help out alot.
To heat your tires up you should see smoke starting to come out your wheel well when looking in your drivers side mirror. Alot of people will count up to 5 or 7 when doing a burnout. Every tire likes a little different heat level, you just have to find out what's best for your tire.sigpic1994 Camaro Z28 83K M6, CAI, AFR 190cc, 11.6:1, Hooker headers, Hooker ORY, Mangnaflow exhaust, AI 230/238, 1.6 RR, B&M Short throw, Hays clutch, 4.10 gear.
