I bought an aftermarket opti and it crapped out immediatley. I recommend only delco opti's. Expensive yes, and ik other people have probably had good experinces with msd and such. Imo delcos are the only safe bet. Your pics are a prime example.
Strange when my GMPP opti shit after only 1500 miles and seeing the most of 5800 rpms when my MSD has been going strong for 4000 and seeing 6300 rpms. MSD FTW
Plus no one else warrents theirs besides MSD
2015 Silverado
OK something to think about. I read somewhere that when installing a new or used or refurbished opti to always measure the peg on the cam and the hole depth on the opti. Once in a while the drive peg is to long and bottoms out and makes the rotor run off balance.
This certainly seems to possible be the case in the picture.
Fix is to grind off end of drive peg.
In this case - not so much. If the dowel was too long and pushing against the optispark, it'd be pushing the rotor away from the optispark. The pics show the rotor being pushed into the optispark.
I have not had an issue with mine at all B and I have had it for 2yrs now.
Looks like your shield was crooked to me.
Someone was stupid and didn't check clearances before the put it on.
I had no issues when I did Red's either!
It all comes down to the fact that when that was put together it should have been check for clearance and it wasn't.
I have had stock rotors touch and you just have to work at it to get them to work.
If he didn't put the spacer plate back in then that could have been half the problem.
