Need LT1 help!
    do you have any intake leaks? and do you know if you have consistent spark and fuel.....umm throttle poison sensor working properly ect.....
      the intake manifold is tightened down pretty good and has nice new gaskets on the head part & front 2 back. any emission lines from the manifold that are no longer in use are blocked off now but i can always re-check that again i guess. it would be so helpful if someone who really knew lt1 engines that lived near lake Orion somewhat could help me figure out what the problem is.
      1996 Trans Am. 355 LT4 + some go fast mods.
      www.360icons.com
      _ Do you have what it takes to become an icon?
      _
      <Atmosphere> Call of duty mw2 summer 10' Ladder
      Gamebattles.com
      Perlsh
        well they are not that much different from a regular engine..... its more than likely a electrical problem aslong as you put everything together right!!!
          it is definitely a electrical issue somewhere, no doubt about it. there was nothing wrong with this new engine besides the bad head gaskets which were caused by re-using old bad head bolts for 1, and a younger kid that was helping me jammed some of the LONG bolts into the portions on the cylinder heads that required MED length bolts .. so improper head seating there, gasket was just messed up a little and there was coolant all over the place.
          maybe something shorted out somewhere ? i cant think of when and how though..
          www.360icons.com
          _
          Gamebattles.com
          Perlsh
            idk just start testing stuff like the coil and sensors ect......
              Are you still back firring?
              Are ALL your plugs wet from fuel?
              What does your spark look like?
              Yellow/Orange or a White/Blue?
              I know you say everything is new but I would do a compression test.
                Yes it is still backfiring.
                Didn't check the plugs after these attempts .. good idea though
                that would at least tell me that fuel is getting to them and determine a lot..
                www.360icons.com
                _
                Gamebattles.com
                Perlsh
                  Ya, I'm trying to figure out if the fuel is getting there or if they are not firring?
                  If they are not firring then I would check to make sure that they are pushed on tight to the Opti.
                  The other thing I'm thinking is you might have something going on with your compression?
                  All cylinders should be with on 10% of each other or less.
                  A fast check is to pull the plug and have someone rotate the motor and see if it's building compression but an actual check is the best.
                    ill check the spark plugs first thing in the morning and let you know how they look, i know the plugs are tight on the opti i double checked that when i re-did the plug wires.
                    and i know its making good compression, when we were bump starting the car to do valve lash you could hear it from each cylinder as valves would open & close.
                    www.360icons.com
                    _
                    Gamebattles.com
                    Perlsh
                      K, that sound good.
                        Another thing too -- if you had your wires wrong and you were getting spark at the wrong time, you might have a few cylinders that could be flooded from the gas. If you put the gas pedal all the way to the floor, it puts the PCM into "Clear Flood" mode which turns off the injectors but keeps the spark plugs going - that way any unburnt gas in the chambers will be burned. Worth a shot, would clear anything out if it's still in there.
                          JC, when you pulled your heads off did you drain the block 1st?
                          Did you remove the water pump when you did this?
                          Did you protect the opti?
                            Optispark is toast.
                            Will this work on my 96 lt1?
                            http://detroit.craigslist.org/okl/pts/1329402274.html
                            www.360icons.com
                            _
                            Gamebattles.com
                            Perlsh
                              don't get a ventless.
                                it will work but i wouldnt i think get a vent-less
