Thats my rearend I believe. The ride height adjusting kit is from global west and makes it pretty nice to raise car to drive around so you don't scrape and then I slam it down all the way at the track but leave back up 1/2" for best times 1.69 60ft.It has 4 inches total adjustment and takes about 15 minutes to do all 4.Then I use the KYB AGX shocks and stiffen front and soften rear.It tops out front suspension like it wants to lift (thinking skinnies)Does both tires rub on inside?Adjustable panhard bar is made to keep rear end centered if lowered.Also the poly ends are not as noisy.
4th gen Suspension question
