Alright guys - I have to say, the trap door method is so damned easy I think it's definitely worth it. We had the fuel pump exposed and ready to start disconnecting everything within 15 minutes. Can't hang the rear end, drop the exhaust, and drop the tank in that amount of time.
We loosely followed the combined directions that Racetronix sent with their pump as well as the how-to found here:
http://www.geocities.com/formulapower2/fuelpump.html
My dad used a 6" cutoff wheel to cut through the floor pan. I let him do it.
While it was scary that it was shooting all the sparks out, I kept telling myself "Tons of people have done this, I've never heard of anyone having a fire..." over and over again.
Once we had the pump exposed, it was a pretty straight forward job. We took our time and goofed around a lot, but all in all it was pretty easy. The only problem that we really encountered was that the hole we cut did not really give us a lot of room to get to the two fuel lines that had the squeeze connections. It wasn't too bad, though, and we got it done.
I went from dropping to 20psi at WOT to staying at 42psi (even looked like it was going UP in fuel pressure at WOT).
And now the pictures -
We spritzed the floor pan down to help cut down a tiny tad on the sparks.
Fuel pump assembly exposed - dad giving his input in the first pic.
Hasn't seen sunlight in 15 years
Soldering/melting the fuel pump bucket together again:
Connecting the two fuel lines again:
Painted the exposed edge with chassis coat just to make sure there was no possibility of rust:
Galvanized steel cover - 20x #8 1/2" screws
All done! Can't even tell the trap door is there.
Thanks for all the ass-shots, Kyle... I'm going to submit those to playgirl and see if I can get some $$$ out of those pics!
