Upper Window Guide
  • Upper Window Guide
    Lookng for upper window guide for my car (the ones that have felt wrapped on them)
    I had issues for awhile and finally took it apart and noticed the rear most guide was cracked and resdy to seperate. Took it apart and it finally broke. Just curious if any body has a junk door laying around that may have a couple of these.
    Otherwise I'm going to attempt a JB weld job on it.
    Craig
    Semi Retired Street Racer
    GONE BUT NOT FORGOTEN
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    - Smokey Yunick
    I dont have em for you Craig but free bump for ya!
      Thanks Darren
      I actually had to adjust the window channel also because for the last year or so the window didn't seem to roll up all the way and seal on the back edge. Come to find out the bolts were loose, I got it perfect now except for that Stabilizer (guide). I removed the front one and put it at the back where it would do the most good. hopefully I can find one cheap or I'll be stuck with the JB welded one. We'll see how that one works tomorrow after it set for 24 hrs.
      Craig
      - Smokey Yunick
