there is an adjustment on the bracket that mounts to the trans by the shift arm. take it loose then you will see clips on top side that release block to slide down releasing center to move forward and back to adjust.
Also could be cable ends worn/broke with to much play in it.
the linkage wasnt even attached to the trans !!!!
both of the 10mm bolts were gone. we got some from my extras box. The trans stays in and goes into every gear, but im sure he damaged it driving it like that for two days
it seems to take along time to accel
