I believe that the mech. gauges require fluid lines ran to gauge (leak and fluid all over) while the elec. uses a sending unit to convert (just wires) maybe look at summit or autometer, see if install for gauge is listed?
alright. i rather not have oil running to my pillar
First off, if you want mechanical, I WOULD NOT use the cheap ass plastic line they give you for it. I'm using a rubber line thats good til like 30,000 psi or something. And also when you use a line that big, it shows every little movement of the pressure. However, I don't think you will be able to run a large line like that up to a pillar. Cehck out 6litereater designs. He makes plates that go where the a/c vents are so you can put gages there.
2015 Silverado
Check out the ES series. The are LED compared to other series that just light up around the gage. They are much easier to see at dark. I have ES boost gage and wideband in my pillar and Sport Comp oil pressure, fuel pressure, and trans temp in the a/c vents.
2015 Silverado
ok, thanks for the advice
what did you do as far as a pillar guage setup? i think i will fab the guage pillar into the pillar with fiberglass or somthing. the shoot both pillars with some interior paint
