3.4 Sea Foam help?
    where do i put in on the 3.8l
    which vacuum line?
    1996 Base Model
    +2 cylinder mod
      which vacuum line?
      I used the brake booster. Here it is on my 3.4
        okay, should i do it to the point where its stalls?
        the you add 1/3 to the gas and 1/3 to the oil?
        1996 Base Model
        +2 cylinder mod
          Follow these instructions: How-To Seafoam Your Car
          This is what I have followed every time I have done it.
          2013 Cadillac ATS
            can seafoam unearth problems? or is it pretty safe to do? my truck has 120k on it and i dont want leaks or anything like that to arrise when i do it.
            you know what they say... "if it's not broke, dont fix it"
              im not to sure, but i am a believer now
              my car has had a rough idle for a while now
              and magically iots gone
              seems to have better throttle response
              1996 Base Model
              +2 cylinder mod
                I've never heard FIRST HAND that it has happened but I have heard that if you have tons of carbon build up against seals that are otherwise bad - it might not be leaking right now but as soon as you seafoam it, you blow away the carbon build up and now there's a chance for the fluids to leak out of the bad seals.
                  I heard that too, Brian - but I never had any issues when I did it on the Camaro.
                  We did it on one of the brother's Mustangs, and man, did it smoke. It was so fun - people were staring.
