My headers are wrapped in that header wrapping stuff, and i was just wondering what the benefit of it is. They're in pretty decent shape, but there are a couple small ripped spots. Should I just remove it all? Re-wrap them? Leave them alone? Does it really do a whole lot for heat reduction? oh and my headers are already out of the car. Thanks in advance!
Header wrapping question
There is a negative to wrapping them...moisture gets retained between the wrap and the header itself...over time this can corrode the header more quickly...
But, yes, they will help keep underhood temps down.Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
Mine are wrapped, and they do keep underhood temps down alot. But there is also a performance reason to wrap them.
Below is from the ThermoTec website.
Wrapping headers with Header Wrap maintains hotter exhaust gases that exit the system faster through decreased density. Increased exhaust scavenging is produced, along with lower intake temperatures.
Best answer so farOriginally posted by TB2 View PostMine are wrapped, and they do keep underhood temps down alot. But there is also a performance reason to wrap them.
and yes it can corrode your headers. it voids most warranties if i remember rightsigpic
Sold!
www.fquick.com/lozanoa11
94 Grand Cherokee (sold)
95 Accord(for sale)
99 Outback (snow destroyer)
this is correct - however, as stated if its not really your application then its more of a detriment than a helpOriginally posted by TB2 View PostMine are wrapped, and they do keep underhood temps down alot. But there is also a performance reason to wrap them.
I read somewhere that it also heats the headers to the point that there may be a burn-through or possible melting. I just saw that most of the headers that I've considered (bike and car) will void the warranty, should they be found to be wrapped and something goes wrong. If you have ceramic coated headers (in/out), the temps are lower than with manifolds. I just go with spark plug shields.sigpic
