LS1 Coolant hose help...
  • LS1 Coolant hose help...
    I got the 2 hoses that go to the radiator, but I need the 2 heater hoses and whatever it takes to hook up the steam tube to the little nipple on the radiator.
    When I go to order these they are shown as "pipe 2 to pipe 3", "water pump to pipe 3", and other nonsense like that. Which ones do I need to order?
    Or does anyone have a diagram or picture that labels "pipe 2" and "pipe 3"?
    could probably just use rubber hose.
    the nipple goes to the front of the TB then the crossover goes on the left side of the TB
      I want to bypass the TB, well I have to as the truck TB just wont work in this scenario.
      Heres why...
        then the rad nipple would hook to the cylinder head crossover
          They are different sizes. Should I buy the one that goes to the TB and the one that comes off of the crossover and connect them?
          What about the heater core hoses? I dont think regular non prebent hose can take the really tight bends without kinking.
            http://adaptiveperformance.com/TB.htm
            the heater hoses should be available at any parts store
              that bypass should be a required first mod anyways.
                I still use mine. don't won't the TB to freeze up while towing the boat through the mountains
                  2015 Silverado
