02 sensers
  • 02 sensers
    keep getting 1 bank and 2 bank errors going to change 02 sensers has any put on the 02 simulators and how did they work out and where did you get them from, need all pro and cons thanks this is on a 97 lt1
    very easy, they are located on the y pipe. they just unplug, you untighten them off. I would recommend replacement delcos if you can find them
      02 sim's are only for downstream(aftercat) 02's
        ha i gotta read better didnt see the sim part
          I also just had to replace my O2 sensors after I put on my ceramic coated headers. Do NOT use anything but AC Delco's
            I would have the rears tuned out rather than buy the sims, also I have had very good luck with my bosch sensors and they have a lifetime warranty.
              Some people have very good luck with Bosch, but I've also read some horror stories. My tuner told me that anything other than AC Delco will not make my car run right. I'm fine spending the little extra $$ just for peace of mind
                When you buy a delco part, its just an oem in a delco box. If one of the oem's was bosch thats what your getting, you could get one of several manufactures buying an ac part.
                  I've got NGK's. Work fine and were pretty cheap.
                  2015 Silverado
                    problems
                    on my second set of 02 sensors ones in car are afs 75 the ones from ac delco say on box the same thing but what is in the box say a different number can't rember what is was well the problem is that every time you go to start it it blows fuses put the old ones back in it doesn't blow fuses just throws codes has any one ever have this problem I think they have a batch of wrong sensors in the wrong box what do you think thanks Pete the guy we are getting them from is suppose to be the gm supplier.
                      running
                      up and running no codes special thanks to Bruce at AGGRESIVE PERFORMANCE for taking the time to find out the problem now she is ready to hit woodward just have to put on snow tires just kidding she doesn't come out if the roads are even wet, too tired to go cruising last night didn't see post about woodward anyway thanks for the help we put ac delco's 02 sensors in it ready to hit milan also.
                        Good to hear Pete
                        Too bad you didn't come out last night there were a few people out including Sonny (you know Who) and Some of the SLP gang (must of hit woodward after Milan)
                        Craig
                        Semi Retired Street Racer
                        GONE BUT NOT FORGOTEN
                        NBM `98 Formula M6 HdTp
                        1 of 1 Build Date 3/12/98
                        - Smokey Yunick
                          So how was the problem fixed??
                            ready
                            wished you would have called got back from Bruce's about 9:00 pm had a long day but would have come out. 5 hours at my grand daughter 2 baseball games in the cold then to Bruce's shop but well worth it ready to rock and roll
