Why does it look like my windshield wipers look like they took Viagra?
  • Why does it look like my windshield wipers look like they took Viagra?
    All right been playing with this all night and can't figure it out. they seem to be working alright except when you turn them off they go all the way up! any ideas??
    Thanks!
    Jack
    i cant remember what the problem is, but i know it was common on the late 90's to early 00's Grand Prixs also. Good luck tho. someone should know.
      Wiper Motor Pulse Board Module maybe
        im guessing they are "bouncing" back up and never sitting at the proper rest point?
        If so yea... its the eletronics of it. my truck had the same issue and it annoyed the crap out of me until i put a new one in.
          Yea this is a common Pontiac problem. Their is a gear that runs with these and sometimes they skip some teeth and park in that upward postition but Its usually what badair said my buddys 99 gtp had that problem and it was that module
            a wiper on viagra..uh oh
              my wipers do that every once and a while and it drives me crazy
                Mine randomly come on all by themselves when I am in the touchless car wash sometimes.
                  wtf thats interesting
                    Yah and I can't get them to shut off unless I shut the car down and let it sit for a minute or so. Scared the shit outta me the first time it did it. Done it like 3 times since bought my car.
                      my truck randomly turned on twice and also wouldnt shut off until i pulled over and shut the truck off for a while. but it happened in dry weather.
                      it would also refuse to work sometimes and just making a "buzzing" noise when i twisted the control. Id have to open the door and help the wiper arm while twisting it and it would start working. I discovered this wasnt a good problem to have when it starts downpouring on you while youre already going 70 mph.
                      i hope my new one never has that problem because it was annoying as hell.
                        i know the problem. take the cowl off and watch the crank arm when it moves.
                        there should be a spring loaded arm on it and when it goes to the bottem its is supposed to go past a tab. if it doesent it wont park right. check if the tab is bent or the crank arm isnt going past it. if its the latter loosent it and turn it a little. common buick problem
                        Sold!
                        www.fquick.com/lozanoa11
                        94 Grand Cherokee (sold)
                        95 Accord(for sale)
                        99 Outback (snow destroyer)
                          park switch
                            i hope you can under stand this
                            Step
                            Action
                            Value(s)
                            Yes
                            No
                            1
                            Was the Wiper/Washer System Check performed?
                            yes:Go to Step 2
                            no:Go to Wiper/Washer System Check
                            2
                            Turn the ignition switch to RUN.
                            Turn the wiper switch to OFF.
                            Disconnect the wiper/washer switch connector C215.
                            Do the wipers park?
                            Y:Go to Step 3
                            N:Go to Step 4
                            3
                            Replace the wiper/washer switch. Refer to Turn Signal and Multifunction Switch Assembly - Disassemble - Off Vehicle and Turn Signal and Multifunction Switch Assembly - Assemble - Off Vehicle .
                            Is the replacement complete?
                            4
                            Measure the voltage from connector C215 (vehicle side), terminal E, to ground with a DMM.
                            Is the measurement greater than the specified value?
                            1.0 V
                            yGo to Step 10
                            nGo to Step 5
                            5
                            Measure the voltage from connector C215 (vehicle side), terminal F, to ground with a DMM.
                            1.0 V
                            yGo to Step 7
                            nGo to Step 6
                            6
                            Replace the wiper motor cover. Refer to Wiper Motor Cover Replacement .
                            7
                            Reconnect the wiper/washer switch connector C215.
                            Disconnect the wiper motor connector.
                            Measure the voltage from the wiper motor connector, terminal E, to ground, with a DMM.
                            1.0 V
                            yGo to Step 12
                            nGo to Step 11
                            8
                            9
                            Repair the short to voltage in CKT 112.
                            Is the repair complete?
                            10
                            Measure the voltage from the wiper motor connector, terminal D, to ground, with a DMM.
                            1.0 V
                            yGo to Step 8
                            nGo to Step 7
                            11
                            12
                            Repair the short to voltage in CKT 113.
                            © 2009 General Motors Corporation. All rights reserved.
                            Shhh!! secret stuff here
                            edit: fixed it so its easyer to read
                            Sold!
                            95 Accord(for sale)
                              Thanks! will try it this weekend!!
