Knock Sensors
  • Knock Sensors
    So, I have all of the parts I need to do my LS6 intake swap, but I am thinking about putting in new knock sensors as well.
    My car is a '98 and I have noticed some knock retard when there shouldn't be any while logging some runs with HPTuners. I have heard that '98 knock sensors can be a bit finicky.
    I think I read somewhere that the later model cars had revised knock sensors as well as wiring harness. Is this true?
    If so, what are the part numbers so I can look them up on SDPC or GMPD?
    i know the 99+ are suppose to be less sensitive but i never heard of a revised harness, just call sdpc
    The LS1 or Go Home Crew
    ASE master certified
      U should do the LS6 PCV conversion while your in there, so you don't have to worry about oil consumption...which these LS1's often have.
      98 Trans Am WS.6
      Cam
      Heads
      Intake
      Full exhaust
      More mods to come
        my stroker had 0 oil consumption without it, for prolly the same price i bet even cheaper you can install a catch can and a breather and be fine.
          The 99+ cars DO have a different harness. I would maybe ask someone on tech if the 99+ sensors can be used with the 98 harness. Alot of the other sensors cant.
