dash removal 99 z28
  • dash removal 99 z28
    Does the A-pilar covers have to be removed in order to remove the plastic dash piece that houses the ambient light sensor and the security light? I plan on installing my in dash nav system soon and plan on mounting the gps antenna under the dash cover. Thanks.
    Yes - the dash pad has a groove that the a-pillar rests in. If you try to remove the dash pad without removing the a-pillar you'll crack it in half.
      Thanks Brian!
        I'm all too familiar with tearing these dash panels out and putting them back in.
        Then again... after doing the swap from 93-96 to 97+ dash myself I guess I should be.
