Low Trac Light Help On My 1996 3800
  • Low Trac Light Help On My 1996 3800
    When i am creeping to a stop and gently press in the brakes, such as pulling up to my house and such, my low trac light flashes. Can any body give me some insight on to what i should check or what the problem could possiblely be?
    Thanks in advance
    1996 Base Model
    +2 cylinder mod
    Thanks in advance
    does it seem to have play in the pedal when it does this? almost like a vibration? When it does this does the tcs off light then come on as well as ABS? My old v6 did this when I put a 4 channel rear end off an 02 SS into the car that had a 3 channel, I unhooked the wiring from the rear end to the car and the lights when on and the issue stopped. Not sure if this is what is going on with yours at all though.
    -Derek-
      is this a f-body?
      this is common on gm trucks. corrosion builds under an abs sensor and causes errors at low speeds.
      another thing can be a wheel bearing. jack up the car and check the bearings
        welp, larry beat me to the wheel bearing.
          Yes its a 1996 camaro, no play in the pedal at all, i was told to check and clean my abs sensor, i wouldnt think it to be the bearings, when i added the new torsen LSD and the Richmond 3:42 i also got a rear end overhual kit with all new bearings and seals
          for now ill check the sensor.
          1996 Base Model
          +2 cylinder mod
            front wheels bearings. you can't remove the front sensors
              well imagine that, i happen to have the car front up in the air with no wheels on it anyway right now lol, i would check it out, but what should i do
              1996 Base Model
              +2 cylinder mod
                put the wheels on. grab the tire at 12 and 6 and wiggle
                  I will try it now, i hate it being dark at 7
                  it needs to snow more or warm up
                  1996 Base Model
                  +2 cylinder mod
                    yea the wheel shouldnt be able to move in ANY direction at all besides forward and backward rotation. if its slopping around at all its toast. When one of mine went bad it was a night and day comparison doing the test larry just recommended.
                      bearings are fine, while checking them i noticed i do need controll arm bushings though
                      1996 Base Model
                      +2 cylinder mod
                        does the abs light come on and/or does abs activate when the light comes on?
                        if not its likely not a hub/sensor issue
                        more likely to be a wiring issue someplace
                          no abs light
                          just the Low Trac one
                          theory ive heard is since my rigth control arms got alot of play in it when the weight shifts the car thinks the wheel is moving while others arent
                          1996 Base Model
                          +2 cylinder mod
